Hi to all,
I have a setup installing an application which at run time could connect with a (fixed) server (by IP).
How can, at install time, check if the server is on?
Or simply check the IP address existence and validity within the net?
It's enough a "ping" command but I should like manage the ping response and show the user a warning box if the server is off (or not existing), so luanching the ping command by dos shell it seems to me a bad idea.
I'm forced to turn to Windows API?
By the way, searching inside MS SDK I hadn't found specific ping-related function, have I to deal with Win32 Internet Functions like FTP/HTTP session-management function?
Thanks to all,
ciao Giuseppe
Pinging remote machine...
gronchi
, Apr 16 2003 14:37
