Are there stipulations when a CA exists in the UI sequence?
CA type 50
Posted 14 September 2001 - 15:36
Posted 14 September 2001 - 18:12
Do you start a Setup.exe (to uninstall previous versions)?
If yes, you have to know that setup.exe (from InstallShield) terminates after launching the IKernel.exe. You can prevent this if you call setup.exe with parameter /sms.
Posted 14 September 2001 - 18:54
Target: [SOURCEDIR]setup.exe /sms
Also, what does /sms do?
Posted 14 September 2001 - 18:59
Posted 14 September 2001 - 19:35
Posted 14 September 2001 - 22:03
If it's created with InstallShield 5 (check the version of setup.exe) note that the parameter /SMS is case sensitive.
Posted 15 September 2001 - 00:23
Shouldn't my CA's wait until it has "finished executing" when I have the option checked? No matter what sequence or where in the sequence it exists?
Posted 15 September 2001 - 17:30
Posted 18 September 2001 - 15:36
First, I would like to say that the new first page of the site is done very tastefully. Simple and meaningful, and very much appreciated by all.
Okay, yes, the file version of third party setup.exe is 5.10.130.0...I tried having my CA to "set a property" set the property to the following:
Source = Run3rdpartyInstall
Target = [SOURCEDIR]setup.exe /SMS
This gave me
"Internal Error 2743. RunInstall, C:\Ngmt\setup.exe /SMS"
this occurred when it got to the point where it ran my CA type 50 "RunInstall" (Source = Run3rdpartyInstall)
....why did it work fine when I ran this actions as type "launch an .exe installed with the
product" in the Execute Sequence? I just ran into this issue once I changed it to a type 50 CA.....
thanks,
Kris
Posted 18 September 2001 - 15:52
Type = 51
Type = 50
Target = /SMS
Also you must have both CAs in the same sequence, because Run3rdpartyInstall is a private property (public properties must be in all upper case). Also C:\Ngmt\setup.exe must exist as uncompressed file in the specified location.
Posted 20 September 2001 - 14:20
Thank you so much.......I was putting the /SMS parameter in the wrong place, like you said. I appreicate your help! It works great now!
Kris
