I am new to the world of msi's. I am working on packaging Flash 5.0 for distribution to a lab. The program has been registered already and I want to disable the registration window that comes up when the program is started. If I cancel the registration the program will not run. I have looked all over the package for the file that either tells it to run or is the file that runs with no success. For others I have found the Eula.ini but this one does not have it. What else should I look for?
Program Registration
griedel
, Oct 26 2001 16:58
Posted 26 October 2001 - 20:59
You have checked the registry haven't you. You can export the registry to a text file before and after you run the install. Then use windiff.exe to compare the before and after snapshots.
Posted 05 November 2001 - 16:58
I am using Veritas Discover for packaging so the msi is contained in a folder with the files and folders needed for the application. I have explored those files and have come up with nothing. I don't know what I am looking for.... Any help is greatly appreciated.... Thanks to all.
