We are trying to run our setup remotely using Terminal Server client. We are finding that self-registering files are not being registered which causes our software to "not work". Previously, we had been using PCAnywhere for remote installations and we had no problems.
Has anyone else had any experience with trying to run setup remotely using Terminal Server?
Running setup remotely using Terminal Server
Dell2
, Jul 24 2002 15:00
Posted 14 August 2002 - 22:26
Yes, I had exactly the same experience. The files do not register correctly. Fortunately I have field techs I can send to install what needs to be installed. But I don't see why you couldn't register the files that need registering manually after the installer is run. Just open a DOS window and do it manually. Keep in mind, I've personally never tried this, but it's worth a try.
Give this a go, and if you need me to walk you through the process, just email me. ccrook@catechnology.com
