Hi all,
Has anyone figured out in which order the shortcuts are created? The order of shortcuts in the start menu is really bad, but I cannot find a way to control the order...
Thanks in advance
Zweitze
Order of shortcuts?
Zweitze
, Aug 26 2003 13:53
Posted 01 September 2003 - 23:15
If you run your install with log mode on then you should be able to see the order
Posted 02 September 2003 - 09:04
I want to control the initial order of the shortcuts in the ProgramFiles menu. Currently, it appears to change with every full build I create. It doesn't appear very reliable this way.
The log file suggests a creation order, but this is not the order presented to end-users.
