I have to log the files which are being installed into a log file . I am using Install shield Developer Ver 7.03 . Is there any event which gets fired when the file is copied onto the system or any other method . I think in Ver 6.x they had an event "On Installing file" where you could write the code to log the file being installed . Is there a similar method in Ver 7.x
Files Installed
manusarin
, Aug 29 2002 15:22
Posted 29 August 2002 - 15:35
Action Data messages are sent by the InstallFiles action for each file installed. You can install an external UI handler to process these messages.
Ian Blake
(Currently Unemployed)
Posted 29 August 2002 - 17:03
Thanks . I am kind of new to Install Shield Dev 7 . Can you tell me how do you install the externa Ui handler . It would be great if you can attach a working example
Posted 30 August 2002 - 11:59
I do not have a sample but there is sufficient documentation in the MSDN/MSI help.
You need to replace setup.exe with your own startup program and make a call to MsiSetExternalUI before MsiInstallProduct. You may also need to do whatever InstallShield needs. (Probably not sufficiently documented).
Ian Blake
Posted 30 August 2002 - 15:52
Note that this will probably not work with Standard Projects in Developer 7 since they already use an external handler I think.
Enabling verbose logging may be the easiest solution.
