We are migrating our installer from an installscript MSI to a basic MSI. However, when doing a major upgrade between the two versions, everything works fine EXCEPT that the old installations icon is left in the add remove programs dialog. Please help. I've been pulling my hair out over this. I've run the upgrade validation wizard between the two MSI's and everything should work fine. Could this be a bug in DevStudio 9?[B]
Thanks!
Upgrading Installscript MSI to basic MSI
jonrodgerwood
, Mar 30 2004 18:14
Posted 20 April 2004 - 08:15
If you are doing a major upgrade, then this should remove the old version.
Maybe run the upgrade install with logging to see that it is actually detecting the old install and upgrading it. This should be in the first couple of lines in the log.
Posted 19 May 2004 - 08:32
Where is this icon taken from? Is it an index into an EXE or is it cached to the %SYS32%\INSTALLER[PRODUCTGUID] folder? Icons are cached on a system and to see a change in an icon that is already cached on the system you need to call the Windows API to refresh the icon cache. Not sure if this is the problem here, just guessing.
