I have WI 1.5
Thank for your help
Posted 29 November 2001 - 14:56
Thank for your help
Posted 30 November 2001 - 21:26
Posted 30 November 2001 - 23:35
I am a little hazy on 1.5 now, but the Registry Data table is definately available under each component.
Posted 03 December 2001 - 10:03
an idea ?
thank you
Posted 03 December 2001 - 12:28
Posted 03 December 2001 - 13:01
key1/key2/key3
i put * for the last key and that remove all the tree, i would like remove juste the last one, because, i can install a second time my application with an other name. This different name is the key3.
thank you for you help an perhaps an other idea !
key1/key2/key3
Posted 04 December 2001 - 10:57
Posted 04 December 2001 - 14:04
Thank for all
Posted 04 December 2001 - 15:06
If you are using ORCA. Create the registry value in the registry table. Note the name in the Registry ifier and Component_ fields . Go to the Component Table and select the row identified by the Registry table component_ field. Set the KeyPath of the Component to the Registry field of the Registry table.
Note the registry values +,-,* are not suitable as component key values.
Posted 05 December 2001 - 14:49
Thank
