I'm using InstallShield 6.3.1.
I use CreateObject to create a COM object (the COM component is written in VB) in setup.rul, and then call a method of this COM object, passing several strings as parameters. It seems that the InstallShiled strings I passed to the method are not the type of string that the COM object is expecting. Anyone knows what's going on here?
Thank you very much!
-Jie
Problem with using COM object in InstallShield
jiekang007
, Oct 02 2002 20:56
