Hi .
I am trying to register a dll file but its failing. Below are the sequence of steps i am doing.
1) Copying the target folders to the system.
2 ) Add the target folder to the path variable. The dll which i want to register depends on the other dll's present in the target folder hence i am adding this path to the system path variable.
3) Register the dll : The installation is not able to complete , i am not sure what is the problem if i manually set the path variable and register the dll then it works perfectly. Kindly suggest what might be wrong.
