Hello every buddy.
i have to get the all user common data application path ...
ie for XP : c: document and setting\alluser\application data and for vista also..
i am using the commonappdatafolder , but there is no folder like this.
i m using instalsheild 2008 an dwindow installer 3.1
thanxs.
jeeban
AllUser common application data path
jeeban_vest
, Jul 02 2008 10:58
Posted 04 February 2014 - 11:26
U can use CommonAppDataFolder variable but because of baqckward compatibility that variable some times creates problem,so you can use below registry entry for accessing commonappdata folder
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
Here you check for value Common AppData.
Aakash Tiwari
