Hello, i have a small problem with the Installshield Developer and I hope that anyone here can help me.
I created a custom dialog with a combo box (also a property for this combo box). Now it is possible to fill this combo box manually with predifined values, but I want to fill this combo box during the installation process.
The problem is that I read out a stringlist at the beginning of the installation, but I can't put these strings into the combo box.
Is there a way to put these strings into this combo box?
Thanks a lot.
Mat
fill a combo box during installation?
mat
, Aug 14 2002 13:42
Posted 16 August 2002 - 12:22
Use the following code. PROPNAME is the property associated with the combo and StringList the List holding the values to be populated.
| Code Sample |
function PopulateCombo(hMSI) LIST StringList, DatabaseList; STRING svString; NUMBER nResult; NUMBER hDatabase, hCBOView, hView, hRec; STRING szText; number index, nCount; STRING sQuery; begin index=0; hDatabase=MsiGetActiveDatabase(hMSI); sQuery="SELECT * FROM ComboBox WHERE Property='PROPNAME'"; nResult = MsiDatabaseOpenView(hDatabase,sQuery,hCBOView); // Allocate space to hold the four properties of a combobox row... hRec=MsiCreateRecord(4); ServerList = ListCreate (STRINGLIST); nResult = GetStringList(StringList); nResult = ListGetFirstString (StringList, svString); MsiRecordSetString(hRec,1,'PROPNAME'); // Combobox name. Must be unique with MSI MsiRecordSetInteger(hRec,2,index); // Position of the line in the combo MsiRecordSetString(hRec,3,svString); // Key String - a string related to the line MsiRecordSetString(hRec,4,svString); // String to be displayed MsiViewModify(hCBOView,MSIMODIFY_INSERT_TEMPORARY,hRec); nResult = ListGetNextString (StringList, svString); // Loop while list items continue to be retrieved. while (nResult != END_OF_LIST) // Display the current element. index=index+1; MsiRecordSetString(hRec,1,'PROPNAME'); // Combobox name. Must be unique with MSI MsiRecordSetInteger(hRec,2,index); // Position of the line in the combo MsiRecordSetString(hRec,3,svString); // Key String - a string related to the line MsiRecordSetString(hRec,4,svString); // String to be displayed // Write the updated row MsiViewModify(hCBOView,MSIMODIFY_INSERT_TEMPORARY,hRec); nResult = ListGetNextString (StringList, svString); endwhile; // Close handle MsiCloseHandle(hRec); MsiViewClose (hView); end; function GetStringList(StringList) begin //populate StringList here end; |
Gunavelu
Posted 19 August 2002 - 10:59
Thanks a lot for your help, gunavelu, it works fine.
Have a good time.
Mat
:D
Have a good time.
Mat
:D
Posted 19 January 2004 - 15:54
Does anyone know how to do this but with a VBS ?
I mean, is it possible to update MSI database at runtime in a vbs CustomAction...
