I've got a customized version of the SdLicence dialog that is done in InstallScript. Apparently, the Edit Field control when created by InstallScript will not correctly interpret RTF files.
I've tried a version of Kent Foyer's code where he uses a static Text Area, but I'm still just getting the raw RTF code. It looks like everything is working properly. Has the code been tested under the IS9 engine?
Is there another way to display an RTF from InstallScript?
How to display RTF in InstallScript project?
StickyC
, Sep 26 2004 20:38
Posted 27 September 2004 - 08:20
It was written for a previos version but I think it should work. Did you copy the script modifications in the dialog script from the sample to your project, in particular the hRichEditCtrl = CreateWindowExA(RTF_WS_EX, ...) part?
