Hello All,
I created one msi using installshield and put some files in it. When i install it on the machine, it makes a registry entry in HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Uninstall\[ProductCode]
However, the uninstall string for this msi says "msiexec /I[ProductCode] . Since to uninstall the msi using product code, we have to use /x instead of /I, so this string seems wrong to me. I checked for other msi installed on the system. For some, the uninstall string shows "/x" and for some it says "/I".
Is there any way, i can edit the uninstall string made in registry of msi.
Saurabh Gupta
uninstall string in registry
saurabhgupta1403
, Jul 12 2010 12:05
Posted 12 July 2010 - 14:21
Don't worry about it. Most of the MS apps are "wrong" but WI is intelligent enough to determine that a product is laready installed and offers the Remove/Repair option as appropriate.
Posted 13 July 2010 - 18:27
| QUOTE (VBScab @ 2010-07-12 14:21) |
| Don't worry about it. Most of the MS apps are "wrong" but WI is intelligent enough to determine that a product is laready installed and offers the Remove/Repair option as appropriate. |
Actually, my msi is supposed to run only in silent mode. So, for end user, if he tries to uninstall it using the uninstall string in registry, it can be an error.
