Hello, I am trying to create a custom action that will run the following command line:
cmd.exe /c start /wait "" "c:\program files\common files\mycompany\myprogram.exe" /MyParameter
I created a custom action type 34 (launch an executable stored in the directory table - SystemFolder) with Target
cmd.exe /c start /wait "" "[INSTALLDIR]myprogram.exe" /MyParameter
When I run the install, the CA runs, but the cmd box only flashes and does not actually run my executable with the parameter.
If I create an install without the CA and run the command line from Start, Run, it works fine.
Does anyone know what I am doing wrong? Any help would be appreciated!!
Note: I get the same results on NT and 2000 (I have not bothered to test it on XP yet).
Thank you,
mmcbride
CA launching cmd.exe
mbmcbride
, Dec 15 2003 23:27
Posted 31 December 2003 - 16:27
I am not able to get it working either.
If possible, try launching the executable directly as a executable custom action. This might resolve the issue.
Posted 31 December 2003 - 18:53
Try putting the actual launch executable command line and parameters into a batch file, then launch the batch file as explained here: http://support.insta...ticleid=q106204
Posted 12 February 2004 - 14:22
Have you tried changing the /c to a /k ? That will keep the command window open and you can see if you get an error message.
