hi,
i have a question about how Windows Installer makes copies in the %windir%\Installer folder.
I use transforms to generate multiple instances of an application. The problem is that when user wants to perform a modify or repair of the application, Windows Installer starts to search for the original MSI which is not always available.
After some research i found out that Windows Installer stores only a small part of the MSI in the %windir%\Installer folder - I guess that this small part is the transform diff.
So i tried to use an embedded transform (at least i think i did), using the MsiDatabaseApplyTransform MSI API function, but the result was the same.
Any ideas on how to force the Installer to cache the whole MSI?
thank,
crush
transform & MSI source file for modify/repair
crush23
, Sep 04 2009 15:03
Posted 07 September 2009 - 08:57
| QUOTE (crush23 @ 2009-09-04 14:03) |
| I guess that this small part is the transform diff. If access to the original source is a problem for your workstations, you should set up your deployments to copy packages locally and execute them from there. |
That guess would be incorrect. The cached MSI is essentially the original but minus internal CABs.
Posted 15 September 2009 - 14:49
Hey,
thanks for the answer, I came to the same conclusion
And form what I could gather, there is no "elegant" way to cache the whole MSI.
Thanks anyway,
crush
Thanks anyway,
crush
