starting README.TXT after installation
Posted 19 May 2001 - 03:55
But for some reason the ReadMe.txt file does NOT open when user clicks Finish button.
I am stuck here not knowing where I am going wrong!
Please help...
Posted 20 May 2001 - 18:42
Posted 20 May 2001 - 21:26
I think what you said is true because i put
NewDialog FilesInUse 1 for the Finish button (in Behavior of SetupCompleteSuccess dialog box) and it did NOT open the dialog box when i pressed Finish button..
But I searched Installshield.com Knowledge base for the key words "engine"/ "start" etc but could not find the article you referred to ...
If you could guide me a bit it would be of great help!!
Posted 21 May 2001 - 02:53
SetupResume,MentanenceWelcome, SetupProgress,Execute Action in Sequence Explorer-->Installation-->UserInterface and it worked.
Thanks for your help, Stefan.
Now I want to launch the readme file only when TWO conditions are satisfied:
1. Installation has taken palce and not UNInstallation (ie COndition = Not Installed)
2. User has checked the check box "Show me readme file"
Now, how should i put TWO conditions in the Condition parameter for FInish button (on SetupCompleteSuccescould do this..s dialog box). Pl help...
Posted 21 May 2001 - 04:34
Prop1 = "Value1" AND NOT Installed
However, in this case, wouldn't it be better to hide the check box when you perform uninstallation? That would mean the user wouldn't be able to select it.
Posted 21 May 2001 - 08:05
The article I was talking about is Q104449
Posted 21 May 2001 - 08:06
Posted 21 May 2001 - 19:57
(I am new to Installshield..)
If you can tell this, it will be of great help!
Thanks in advance..
Posted 21 May 2001 - 21:47
But the pb of hiding/disabling after uninstallation still exists...
thanks a lot for your help
Posted 22 May 2001 - 10:37
Can I suggest that we finish this topic here and carry on in the other one? It'll save confusion for people searching the forum in the future.
