I'm using InstallShield Windows Installer Edt. v2.02, and my setup is creating a standalone Setup.msi file.
When the user is uninstalling the programs installed by Setup.msi, the InstallShield wizard requires the original Setup.msi file.
The problem is: In case it cannot be re-located, the programs cannot be uninstalled!
With another InstallShield project, I was able to get around this "bug" by changing the sequence of a Custom Action.
This time, I testwise removed all Custom Actions, already.
Help! & Thanks for any ideas.
Deinstallation w/o orig. Setup.msi
unwise.exe
, Sep 30 2002 18:19
Posted 02 October 2002 - 08:39
There is a standard action called ResolveSource, make sure this has a condition of "NOT REOMVE".
This will then use not call this action when you remove the product. The system cached copy of the msi will be used.
Posted 04 October 2002 - 08:18
Thanks. - I re-created the setup from the scratch, and now it works (BTW - there's still no condition on executing ResolveSource). - Do you mean the original setup.msi is needed at any rate, when it's been removed from the cache?
Posted 07 October 2002 - 08:55
Your system cached copy will have a resolve source action and a condition on it. This will be used for the uninstall.
