How can I change standard installer icon on the title bar, left of the [Product Name]. First of all, how can I generate a bitmap with extension ".ibd" and is it possible to use that bitmap for the title bar not for the dialog.
And if solution requires modifying .msi file, i need to compress all files into a setup.exe, so is it possible to first generate .msi and modify it and convert back it to .ism and generate .exe file? I have read some related notes in the forum, but still I can't get the point, maybe this is because I have never used ORCA or any other tool, isn't there any easy way to do that with ISWI 2.03?
Metin SENKAL
