anybody knows , how to define an user defined function and call the function from somewhere.
I tried to define a function and use it one event handler ONBegin() , the comipler complains that there is an invalid end statemement
.I am used to IS 5.X and hence I could place the functions anywhere in the main program and compile it, but now IS 6.X has many event handlers and functions and I tried to define the function in the event handler it is giving compile errors.
Any help is appreciated.
A
Installsheild unexpected end of source
anjalai
, Oct 22 2003 21:16
Posted 23 October 2003 - 00:47
I'm assuming you're doing all this in setup.rul right?
In which case, just have a function declaration at the top in between your header inclusions and script inclusions, and later on have your function definition. Here's a quick example that you can look off of as a comparison:
| // Include header files #include "ifx.h" //DO NOT REMOVE ////////////////////// string defines //////////////////////////// #define INSTALL_KEY_BASE INSTALL_KEY_BASE_5x #define INSTALL_KEY INSTALL_KEY_5x //////////////////// installation declarations /////////////////// // your DLL function prototypes // NONE // your script function prototypes prototype Program(); prototype InstallInfo_Components(BOOL); // your global variables STRING svSerial; // Include script files #include "project.rul" #include "Common.rul" #include "Entivity.rul" #include "LiveBased.rul" #include "Live.rul" program Program(); // THIS IS TO SIMPLY TO SPEED UP ACCESS TO THIS SECTION OF CODE endprogram function Program() begin end; function InstallInfo_Components(bSave) begin LiveInstallInfo(bSave); end; |
Hope it helps, but if not, please post a copy of your of your code and the exact compile error, so we can tell you how to properly fix it.
Edited by Taco Bell, 23 October 2003 - 00:47.
