I need to create MSI package that changes .dwg file type properties with following logic.
- If autocad is installed let .dwg association point to autocad. So no changes to system.
- If autocad has not installed. Program a.exe (a component of mine installation) should open the file when double cliked.
So far i have managed to create a system search ACADINSTALLED that looks c:\acad folder existence.
Also i have managed to create a.exe component that opens .dwg files when double cliked.
If i create a separate component that has only a information necessary to associate .dwg to a components key file i'm unable to bind it specifically to a.exe. Instead .dwg open command points to key file of component.
How do i associate .dwg to a.exe so that i can choose whether i do it or not at install time.
File extension association with a twist
HahtokariMika
, Sep 28 2005 07:28
Posted 28 September 2005 - 15:41
You may create a new component that creates this registry entry. This component should be installed when your a.exe is getting installed AND the autocad is not installed.
ankur tyagi
Posted 04 October 2005 - 11:07
Thanks, i'll try that one.
Not as clean solution as i hoped for, but i need to make this fast.
