I have a com+(written in vb) component that need to be registered in component services as a "library application". i've tried using the component wizard on installshield but I just ran into more problems. I've tried modifiying the com+ tables but I don't know anything about the export flags. Any ideas on how to get these components registered and working. What's strange about this is the fact that If I manually register this file first everything works fine, BUT if i register this file AFTER running the install all of the names are missing from the component services ui for the app.
Setup using com+ dll
Thundr51
, Apr 02 2001 15:22
