im having issues on some of our machines with an IS script. This is a packaged application which includes the isscript.msi but for some reason only some machines are failing with this error. Im assuming they have a different scripting engine installed perhaps but haven't been able to confirm ? Is there a way to find the installed versions of ISscript ? any ideas on why this isnt working ?
=== Logging started: 22/03/2004 12:07:21 ===
Action start 12:07:21: INSTALL.
Action start 12:07:21: ISMsiServerStartup.
Action ended 12:07:21: ISMsiServerStartup. Return value 1.
Action start 12:07:21: ISStartup.
1: The InstallScript engine version currently installed on this machine is adequate.
1: Event 'E722112' is created
1: GetInstallDriver, Can not find InstallDriver in ROT table, Return Code = 0x800401e3
1: {2446B8DB-2FFC-4301-8765-88734AF4DC04}
1: Extract supporting files
1: Failed to extract _IsUser.dll, Ignore it.
1: ISMsiServerStartup Failure, Failed to Initialize script support, Error = 0x80070005
1: MsiServerStartup failed. Abort installation.
Action ended 12:07:23: ISMsiServerStartup. Return value 1603.
Action ended 12:07:23: ISStartup. Return value 3.
Action start 12:07:23: ISCleanUpFatalExit.
1: Shutting down the PRC server...
MSI Server startup thingo
huckey
, Mar 22 2004 16:58
Posted 03 August 2004 - 06:38
the package may not have rights to install the isscript.msi.
Just a guess.
-Aaron
Just a guess.
-Aaron
Posted 03 August 2004 - 08:44
There are tons of knowledge base articles about this issue at Installshield. Go to http://support.installshield.com and search for it.
