Hi
I have a single .ism project.The setup CD has a folder along with the setup.exe whose content can change and it is this folder whose contents get copied on to the machine on which setup is to run.What i want to do is generate GUID on fly in the install script so that the GUID provided by me gets registered in the registry under various heads where Insallshield enters the GUID.
I have tried doing this using
MsiSetProperty(ISMSI_HANDLE,"ProductCode",sValue)
when i retrieve the value using
MsiGetProperty(ISMSI_HANDLE,"ProductCode",sValue,nVal)
it gives me the value specified by me.But lookin into the registry i see the ProductCode which was genereated by Insattlshield itself.
Can some one tell me how i can achieve this
Thanks in advance
Specifying GUID value in InstallScript
Manu
, Jul 02 2003 11:17
Posted 03 July 2003 - 09:53
Did you read this article: "Setup Launcher to Suppress Maintenance Mode in IS6 and ISD7" at http://www.installsi...tt_cdbrowse.htm
