By default win 2003 come with no IIS, no www, and no asp
If you like to add then you need to go to add/remove program window components and select the “feature” to install
My q is how to detect during the install that the asp is install on the target machine?
asp and win 2003
arik__y
, Jun 06 2004 17:09
Posted 09 June 2004 - 02:40
If ASP is installed using windows installer you should be able to query the windows installer database for the product GUID the install uses. Try to install ASP and use MSIZap to see a list of all Windows Installer setups on the system. The good news is that if the ASP is a real windows installer setup you may be able to automatically invoke the installation of it during your own setup.
Posted 10 June 2004 - 11:32
Hi and thanks for your replay
I found a registry key that give me the necessary information
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\OC Manager\Subcomponents\
iis_asp 1/0
1= on 0 = off
You can read more here
http://www.microsoft...d/13_s3iis.mspx
iis_asp 1/0
1= on 0 = off
