The following fixes are related to the Windows Installer (MSI) engine. Therefore I expect these fixes will also be included in the MSI 3 runtime installer for other Windows versions:
- 309495 Problems with Windows Installer Over Wireless Connection
- 811364 FIX: Error 1308 When You Install a Program from an Internet Source Location
- 823116 You Receive Error 1913 When You Install a Program on Windows XP
- 839962 An incomplete list of associated running programs is displayed when you remove a program in Windows Server 2003
The following issues have been fixed in the operating system, not the MSI runtime. Some of them also affect non-MSI setups:
- 328213 Adding or removing a program may generate Event ID 7023
- 811148 Windows Installer Custom Action Does Not Start a Program If the Program Has Already Started
- 811996 A Windows Installer Package That Is Installed with Group Policy Does Not Restart the Computer
- 834503 You receive event ID 36 and a "Windows File Protection" error message when you install a software update for a second time
- 828452 An Assigned Package Is Reinstalled Every Time Clients Log on to the Domain
- 810019 InstallShield 5.5 Setup May Run Slowly with the Bluetooth Supplement Installed
