Hi all,
I'm new to InstallShield so forgive me if this is a stupid question...
I'm using Installshield 12 to install a .NET 2.0 application. I had been using VS2005 setup project which included a number of Custom Actions, but have decided to use a more advanced installation editor.
I'm wondering whether to continue using Custom Actions with Installshield, or whether to just use InstallScript.
Is there a general consensus as to whether Custom Actions are better than using Installscript or vice-versa?
Any thoughts welcome.
Rik
For info: the Custom Actions setup the .NET CAS policy, made changes to the configuration file, and setup the registry.
Newbie: .NET Custom Actions or InstallScript
RikRak
, Sep 18 2006 12:55
Posted 18 September 2006 - 21:42
Using custom actions is better in a Basic MSI project is better than using the InstallScript MSI project type.
You can have custom actions in a couple of formats, including DLL, EXE, VBScript, InstallScript, .NEt Installer Class. A DLL written in C is often the leanest and most stable solution. Custom Actions written in InstallScript require some overhead. Custom actions in managed code (c# for instance) should be avoided.
Posted 19 September 2006 - 15:09
Thanks Stefan,
Is there any reason why managed custom action should be avoided? Is it because the framework is required prior to installation?
Rik
Rik
Posted 19 September 2006 - 17:02
See this blog article for some discussion:
http://blogs.msdn.co.../10/392280.aspx
Also note that you are very restricted in scheduling "installer class" custom actions.
