Wise Installer has a merge function which requires the (1) filename of the merge module, (2) a feature name and (3) a directory name and it will perform the merge.
This is pretty much what I want to do but without requiring Wise. Has anyone got any sample code for doing this, looking at MSI.CHM, it looks a lot harder than this. I have seen posts on cab files etc also, I don't see why it need be harder than a 'C" #include...
Thanks for any help,
Dennis
"#include" Merge Modules
dbareis
, Jan 28 2003 00:34
Posted 28 January 2003 - 00:34
Dennis Bareis (dbareis@No.Spam.gmail.com)
Free MSI update/creation tool (MAKEMSI):
http://users.cyberon...eis/makemsi.htm
Posted 28 January 2003 - 14:09
have you looked at the Windows Installer Development Tools ?
there is a MSIMerg.EXE there ( look it up in the same MSI.CHM file ) that might satisfy your reqt's...
Posted 28 January 2003 - 22:45
Hi.
Thanks for the response, I do look at these as lots of stuff is only "documented" there!
The merge script merges two databases and this appears to be a another type of process which is not what is done for merge modules.
It is starting to become clearer to me, the main issue is I don't know much about how files are stored in cab files, I think I'll be starting there, and getting that working first and then the merge module issue will hopefully seem a lot easier and the documentation might make more sense.
I am writing a tool which takes a text script (not code as such) and generates appropriate VBSCRIPT to do whatever you wish (for example create MSI). It is coming along nicely, the file/cab and merge modules are the only things I can see which I'll probably have lots of "fun" with.
Bye,
Dennis
Bye,
Dennis
