I am able to create the DSN using the ODBC Resources but my requirement is that needs to be created dynamically since the customer can provide/maintain the DSN in any name.
So I created one custom dialog which accepts the DSN information. Now I want to create the DSN using the given value. How to do that?
Your help would be appreciated.
DSN Creation
vijijs
, Dec 07 2005 14:19
Posted 11 July 2006 - 22:34
You can create the DSN by writing to the Windows Registry.
Below is a vbs example, that you can use for inspiration.
User DSN's are written into HKCU.
System DSN's are written into HKLM.
'--------------------- script begin
Dim DataSourceName
Dim DatabaseName
Dim Description
Dim DriverPath
Dim DriverName
Dim LastUser
Dim Server
Const SystemFolder= 1
Dim fso
Dim SysFolder
Dim SysFolderPath
DataSourceName = "DSNName" 'Change this
Description = "Data Source Description" 'Change this
Server = "ServerName" 'Change this
LastUser = "DBUser" 'Change this
DriverName = "SQL Server" 'Do NOT change the driver name if using SQL Server.
Set fso = wscript.CreateObject("Scripting.FileSystemObject")
Set SysFolder = fso.GetSpecialFolder(SystemFolder)
SysFolderPath = SysFolder.Path
DriverPath = SysFolderPath & "\sqlsrv32.dll"
Set WshShell = WScript.CreateObject("WScript.Shell")
Dim RegEdPath
RegEdPath= "HKLM\SOFTWARE\ODBC\ODBC.INI\" & DataSourceName & "\"
WshShell.RegWrite RegEdPath , ""
WshShell.RegWrite RegEdPath & "Description" , Description
WshShell.RegWrite RegEdPath & "Driver" , DriverPath
WshShell.RegWrite RegEdPath & "LastUser" , LastUser
WshShell.RegWrite RegEdPath & "Server" , Server
WshShell.RegWrite "HKLM\SOFTWARE\ODBC\ODBC.INI\ODBC Data Sources\" & DataSourceName , DriverName
wscript.Quit
'----------------- script end
Best Regards
Mikael Sorensen
Dim DataSourceName
Dim DatabaseName
Dim Description
Dim DriverPath
Dim DriverName
Dim LastUser
Dim Server
Dim fso
Dim SysFolder
Dim SysFolderPath
Dim RegEdPath
wscript.Quit
Best Regards
Mikael Sorensen
Posted 12 July 2006 - 13:21
Or if the aforementioned is not satisfactory you can use ODBC programming (the sample is from MSDN). Yes you need to "import it " to script but is simple and even you can find on the sample part of this site the code I think.
#include <stdio.h>
#include <windows.h>
#include "sql.h"
#include <odbcinst.h>
int main()
RETCODE retcode;
UCHAR *szDriver = "SQL Server";
UCHAR *szAttributes =
"DSN=MyDSN\0DESCRIPTION=SQLConfigDSN Sample\0"
"SERVER=MySQL\0ADDRESS=MyServer\0NETWORK=dbmssocn\0"
"DATABASE=pubs\0";
retcode = SQLConfigDataSource(NULL,
ODBC_ADD_DSN,
szDriver,
szAttributes);
#include <stdio.h>
#include "sql.h"
int main()
RETCODE retcode;
"DATABASE=pubs\0";
ODBC_ADD_DSN,
szDriver,
szAttributes);
