Hello!
I try to use the BrowseForFile DLL from http://www.installsi...owseForFile.zip I inserted the BrowseForFile.dll in the support files section.
Then I do the following in the install-script:
prototype BYREF STRING BrowseForFile.BrowseForFile(BYREF STRING, BYREF STRING);
szFilter = "Certificate File (*.cer)\0*.cer\0";
UseDLL(SUPPORTDIR ^ "BrowseForFile.DLL");
BrowseForFile.BrowseForFile(szCertificatePath, szFilter);
MessageBox( "Selected Path: " + szCertificatePath, INFORMATION );
UnUseDLL(SUPPORTDIR ^ "BrowseForFile.DLL");
I get the error 0x80040704
What's the problem, how can i prototype this function and call it after that?
Here's the code of the dll:
Calling BrowseForFile DLL
blood_on_ice
, Mar 17 2008 11:15
Posted 17 March 2008 - 11:15
//*********************************************************** //** This source code is provided "AS IS" with no warranties, //** and confers no rights. //*********************************************************** #include <tchar.h> #include <windows.h> #include <shellapi.h> #include <shlobj.h> #include "msiquery.h" #include "strsafe.h" //*********************************************************** //** Call back function for EnumChildWindows() //**--------------------------------------------------------- //** Author: Kallely L Sajan //*********************************************************** BOOL CALLBACK EnumChildProc(HWND hwnd,LPARAM lParam) { TCHAR buf[100]; GetClassName( hwnd, (LPTSTR)&buf, 100 ); if ( _tcscmp ( buf, (_T("RichEdit20W")) ) == 0 ) { *(HWND*)lParam = hwnd; return FALSE; } } UINT __stdcall BrowseForFile(MSIHANDLE hInstall) { //MessageBox(NULL, "BrowseForFile", "BrowseForFile", MB_OK); //Set up storage for PATHTOFILE TCHAR szOriginalPath[MAX_PATH]; DWORD cchValue = sizeof(szOriginalPath)/sizeof(TCHAR); ZeroMemory(szOriginalPath, sizeof(TCHAR)*MAX_PATH); // Get PATHTOFILE MsiGetProperty(hInstall, TEXT("PATHTOFILE"), szOriginalPath, &cchValue); long lErrMsg = 0; OPENFILENAME ofn; ZeroMemory(&ofn, sizeof(ofn)); TCHAR szFilters[] = _T("All Files (*.*)\0*.*\0") _T("Text File (*.txt)\0*.txt\0"); // Initialize OPENFILENAME structure. ofn.lStructSize = sizeof(ofn); ofn.hwndOwner = GetForegroundWindow(); ofn.lpstrFile = szOriginalPath; ofn.nMaxFile = sizeof(szOriginalPath); ofn.lpstrFilter = szFilters; ofn.nFilterIndex = 1; ofn.lpstrFileTitle = NULL; ofn.nMaxFileTitle = 0; ofn.lpstrInitialDir = NULL; //ofn.Flags = OFN_PATHMUSTEXIST | OFN_FILEMUSTEXIST; //ofn.Flags = OFN_HIDEREADONLY; if (GetOpenFileName(&ofn)) { MsiSetProperty(hInstall, TEXT("PATHTOFILE"), szOriginalPath); //This next bit of code fixes a problem that occurs if the author is //using an Edit box for the path. For whatever reason, if a user //types into the edit box before browsing for a file or folder //the Edit box is not updated once the custom action completes. //Much of the following code was modified from //Kallely L Sajan's IsLicensedViewed article from InstallSite.org HWND hWnd; HWND hWndChild=NULL; hWnd = FindWindow(NULL, "Default - InstallShield Wizard"); if (hWnd) { EnumChildWindows( hWnd, EnumChildProc, (LPARAM)&hWndChild ); if ( hWndChild ) { TCHAR buf[100]; _tcscpy(buf, szOriginalPath); //the following call will not work if _UNICODE is defined in Prepocessor definitions SendMessage(hWndChild, WM_SETTEXT, 0, (LPARAM)szOriginalPath); } } } return ERROR_SUCCESS; } |
Kind regards,
Peter
