I have created a .msi package using VS Installer that has 3 components, 2 of which are custom ones that we have created ourselves.
When I click the msi file to remove the installation it only removes the 2 custom components.
Is there any reason for this?
Thank you for any help.
Polly Anna
Uninstall does not remove files
PollyAnna
, Mar 17 2005 18:01
Posted 18 March 2005 - 11:13
Generate a verbose log file of the uninstall to see what's going on:
http://www.msifaq.com/a/1022.htm
Posted 18 March 2005 - 18:10
Thank you very much for the help.
Your article has a slight mispelling
the command name is
msiexec.exe
Thank you again,
Pollyanna
the command name is
msiexec.exe
Thank you again,
Pollyanna
Posted 21 March 2005 - 09:24
Thanks for pointing this out. I'll fix it.
