I have defined a property using property manager giving a default value.
I have defined the property name in caps, so that i can modify the value during installing. I am trying to set this property in the OnFirstUIBefore method available in setup.rul, when i compile setup.rul it throws a error saying " error C8025: 'CHECK' : undefined identifier ".
here 'CHECK' is the userdefined property(the property which i had set in the project manager) .I am using installscript msi project. How to i associate the property which i had defined in property manager with Setup.rul, should i import anything?
Alamelu
How to set the user defined property in setup.rul?
Alamelu
, Apr 27 2005 05:27
Posted 27 April 2005 - 07:17
Did you try MsiSetProperty ?
