Hi, there,
I found a problem. I created a new installation to upgrade the previous version. And then, I uninstall the package, the NT services will not remove automatically.
It could be found in the Services List with its status is start.
My platform is InstallShield 10.5 Premier Edition.
After major upgrade, NT services will not remove.
danielxu22
, Sep 29 2005 11:57
Posted 30 September 2005 - 03:04
This my services control event setting. What do you think of this?
BR,
Daniel
BR,
Daniel
Posted 30 September 2005 - 14:52
Did you change the component GUID for the component installing this service between releases?
Posted 08 October 2005 - 04:20
| QUOTE (Glytzhkof @ 2005-09-30 14:52) |
| Did you change the component GUID for the component installing this service between releases? |
No, I never change the component GUID.
Posted 19 October 2005 - 09:58
Did you try to reboot after the installation and check whether the service is still there?
Posted 20 October 2005 - 03:05
| QUOTE (Glytzhkof @ 2005-10-19 09:58) |
| Did you try to reboot after the installation and check whether the service is still there? |
Yes, I tried. But the service is still there.
And now, I added a Componet of Services Control to delete the services when uninstall, with Service Argument "-r".
The problem was be settled.
Do you know another solution? Or this is a bug, right?
BR,
Daniel
