I need to disable the change button in the DestinationFolder dialog only if an expecific value in a key of the registry exists. I know how to verify the values in the registry with an script but i can't disable the button in the dialog. Anyone knows how to do it?
Thanks for your help
Disable a button
davidgamo
, Dec 14 2005 11:29
Posted 14 December 2005 - 11:56
Add this row to the ControlCondition table:
DestinationFolder ChangeFolder Disable MyProperty
MyProperty is the value you set when you verify the value of the key
Posted 14 December 2005 - 12:44
Thanks lavocat
The problem is i don't know how to access the value of a property from my script. I create a new property in the property manager. I try to change the value of this property from my script but when i build i get an error message(C8025).
How i do it?
How i do it?
