Hello,
I am using InstallShield Developer SP2 and install script project.
When I run my setup program from local machine it works correctly.
When I place the setup files on a network drive and run it, it does not work.
Some of the script code is executed and some not. Some files are copied and some are missing. I tried to use UNC\share_name or to map the drive but it still does not work.
Does anyone have an idea how to allow centralized installation from a network share directory ?
Running setup from network drive
harel
, Jan 11 2006 18:02
