Posted 08 January 2007 - 18:42
Hi Stefan,
Thanks for your reply. Supplying a second file with my setup is not an option right now. I am wondering if there is a CA or MSI Property I can set which will force the UI Sequence to prompt for elevated privilages. I am working in ISWI2.03 and the msi (when double clicked) cannot unload the IS Kernell files to the OS. This causes the setup to fail immediately, after that there's a couple of CA's that write to HKLM and Program Files. I don't have the option of changing these locations as my setup is highly customised and designed for Sophisticated User deployment on (generally) Win2k3 Servers typically 1 or 2 per Organisation. They are not for use by standard desktop users. A request from one of our customers has come in to support Vista, and turning off UAC is not an option for them.
I know MS haven't provided direct support for pushing the UI Sequence into Elevated mode directly, but I'm hoping there's a hack out there. It seems pretty rediculous that they'll allow the UI sequence to execute with elevated privilages when the MSI is launched from a Setup.exe, but don't provide a method of forcing to to run with elevated privilages from within MSI itself. My simplest workaround is to create a shortcut to the msiexec /i xxx.msi and right click then Run-As-Administrator, which runs the UI in elevated mode. Surely there's a little hack which will get around that farcical extra step.
