Running the installer under Windows 2000 SP2, I've been able to use custom action 19 errors, as well as returning ERROR_INSTALL_FAILURE from functions in a DLL. In these cases, the installer will invoke the FatalError dialog and gracefully exit when the user clicks the finish button. However, if I run under a vanilla install of Window 2000 (no service packs), I get the following error messagebox:
| Quote |
| The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2735. |
If I click OK, my installer simply hangs. Is this a backwards compatibility issue of some sort? Is there a way to workaround this problem? Any thoughts or suggestions would be greatly appreciated.
