We are developing an application that requires the installation of other stuff, such as MDAC and Logitech's QuickCamExpress SDK. Logitech's SDK uses InstallShield.
However, I cannot get SDK's setup not to reboot at the end of its installation process. Before installing SDK, I did run setup.exe -r to record everything, followed by setup -s to "playback" the installation.
The result was that I once more got SDK's reboot dialog and had to manually choose not to restart so that the installation process of our application. I would expect that the dialog would retrieve its answers from the iss file, sparing the user from having
to manually choose the no-restart option.
In fact, when I run setup.exe -s I get three dialogs: Welcome, Licence and Restart. Correct me if I am wrong, but I did not expect to get those dialogs if I am running in silent mode.
I am using the InstallShield that came bundled with Visual Studio 6. The OS is W2K SP2.
The iss file I used follows below. Any ideas would be greatly appreciated.
Armando
