using ISWI 1.1 I defined for a component a desktop shortcut. I set the parameters (working directory, ...) in the concerning dialog of the component in the ISWI IDE. I ran the the setup on different PCs under NT 4.0 (Built 1381, SP6). The shortcut was installed on the desktop on every PC and it works properly.
The problem is now that the properties of the shortcut on the desktop are not available on every PC. On one PC I open the context menu of the shortcut on the desktop (right mouse click on the shortcut), open the properties dialog and I can change the parameters (e.g. working directory). On another PC (same operating system!) the properties dialog opens but all edit fields are empty and grey (inactive). But this shortcut works properly too.
What´s the problem of this shortcut?
Ralf
Edited by Ralf, 12 April 2003 - 22:59.
