I'm fairly new to msi packaging and this site, so don't know if this is a relevent post.
I've done a setup capture of the sources which require the disc to run, my problem is that my msi still requires the disc to run, is there anyway around this,or anything i can try
I'd appreciate any help anyone could give me
please insert disc into your cd-rom drive
draco
, Aug 24 2005 09:28
Posted 24 August 2005 - 18:15
Please post your question only once (this saves me the work of deleting the duplicates).
I don't know which tool you are using to capture the setup, but you need to make sure you build the application files into the package, instead of referencing from the CD. This may be a setting in your tool.
