Now I've already wasted a few days to fix my problem.
The integrated debugger won't start to lauch, after I've updated the InstallShield Developer
Version 7.01 to 7.03 on Win 2000 SP2. Even deinstall IS, cleaning registry and directory entries,
and reinstall IS won't fix the problem!!!!!! Pressing the push button "F8/debug InstallScript..."
will start the compiled setup routine only, without debugging control.
To work and deliver a standard project I've realized it with InstallShield 5.5.
Now -after the holidays- I've still the old unresolved dammend problem....
Some other problems are unresolved, f.e. the button "search Updates..." in menue "Extras"
which simply does nothing. Updates are reachable only via CD and post dispatch.
On an old partition with WinNT (start partition is H:, but using the same
installation directory "c:\program files\InstallShield\...") I've the same problems.
Q: Who knows about this problem? Any Hints?
Q: Is it possible to start the debugger separately? Has anyone an example for me?
debugger does not launch
reitinger
, Sep 16 2002 16:02
Posted 16 September 2002 - 18:19
Moving this question to the Developer 7 forum (you posted in professional 7 forum)
Posted 16 September 2002 - 18:24
I guess you are using the German Edition
This is a known bug, documented here (including fix):
http://www.installsi...bugs_isd703.htm
in section "InstallScript Debugger Doesn't Start in German 7.03"
Updating to 7.04 should also fix this.
