Hello
I have a little problem with my MSI file.
The MSI consists files , CA and some MSMs.
When I finish install my application after 1 min approximately its run the MSI
again.
The wierd thing is that i cannot see the Dialogs but the first MSM if starting and so on...
Mabye someone know what problem can cause such behavior
MSI run several times
Mr.B
, Jan 24 2005 12:40
Posted 24 January 2005 - 14:17
Posted 24 January 2005 - 14:55
Thanks A lot
Its is Exactly the problem !
But how do I shut down the Auto repair feature ???
Posted 24 January 2005 - 15:18
Hi Again !
I think I found the problem caused this auto-repair.
In the installation i install 10 files to a Temp directory inside my TARGETDIR.
then in the custom action i check if i need to copy them to a specific location and delete the temp dir or just delete the temp directory
When I check the event viewer i get 1001,1004 errors about these files.
The problem is i dont need them there and i delete them through CA.
Any suggestion how can i fix it ???
Posted 25 January 2005 - 14:43
Don't make these files key file of a component.
