1. Under standard setup, a MSI is created for you. Are you supposed to be allowed to run the MSI alone or is it just used by setup.exe?
Thank you,
Enoch Chum
2. Can you convert a standard setup project into a Basic MSI project?
3. Are there any tutorials out there on how to create a Basic MSI project because I couldn't get it to work. I the following error upon running the MSI file.
Internal Error 2235., RuntimeFlags, SELECT 'Component', 'RuntimeFlags', 'KeyPath' FROM 'Component' WHERE 'Component'=?
