We're to the point of integrating our IPWI 2.03 projects into our CM build process. We can't find a command line or INI file entry to specify the merge module location.
Our CM process uses mapped/subst'd drives to specify the location of the build and an environment variable is set to reflect whatever that is. I need to be able to specify a location for my merge modules based on that environment variable.
I tried changing my project's merge module location string to include %CMBLDDIR%\staging, rather than E:\Dev\staging, and it told me that the directory didn't exist and asked if I wanted to create it. We also tried modifying the registry, but it won't take the environment variable spec, either.
Any suggestions?
Thanks!
Shan :)
