is there any way of inserting a line return in the Target field of a CA type 19?
CA type 19 - line return
dtasanas
, Feb 23 2005 22:44
Posted 13 May 2005 - 15:10
The interface in Wise products allows this very easily. I've never tried with Orca.
An obvious workaround is to use a property - here's a line of vbscript to create one:
Property("TESTPROPERTY") = "Line1" + vbCrlf + "Line2" + vbCrlf + "Line3"
Posted 13 May 2005 - 15:29
I was curious, so I checked Orca.
If you export the "customaction" table, you find the following characters between lines: "". I've no idea how you'd type these into the orca interface (other than cut and paste).
