Can anyone help. When running my installation via Terminal Services, I receive a message "Internal Error 2755, 3, product.msi". This always occurs just as the "ExecuteAction" action occurs in the sequence.
Any suggestions would be much appreciated.
Thanks.
Standard Actions when using Terminal Services
InstallDude
, Aug 21 2001 02:46
Posted 21 August 2001 - 04:14
I'm guessing that you are running the installation over a mapped drive. This is a fault with the Windows Installer service. Try running the install over a UNC path, or copying it to the local box before running it.
I think it has something to do with the installer service running as the Local System, while drive mapping are defined on a user basis.
Posted 21 August 2001 - 15:37
Thanks Leigh. Your suggestion was a great help and the installation worked. The mapped drive problem seems to only exist when installing via Terminal Services. If T.S. is not involved, it installs fine from a mapped drive. Thank you very much and have a great day!! :-)
