Prerequisites dialog
cornel_gav
, Apr 23 2008 16:28
Posted 23 April 2008 - 16:28
I want to display the prerequisites dialog after the actual installer starts, somewhere after "InstallValidate", not when the setup begins. Can I change this?
Posted 24 April 2008 - 14:49
Not with InstallShield 2008 or older.
Posted 24 April 2008 - 14:58
Never done it but I imagine playing with the sequencing in the InstallUISequence and InstallExecuteSequence tables might work...
Posted 24 April 2008 - 15:06
Prerequisites come from setup.exe, before the msi part of the install is launched.
Posted 24 April 2008 - 16:09
So this topic should probably be moved from 'Vendor-neutral MSI topics'?
I imagined the OP had a custom dialog...
Edited by VBScab, 24 April 2008 - 16:10.
Posted 25 April 2008 - 17:48
Oh, it was only my assumption that cornel_gav is using InstallShield.
@cornel_gav: are you using InstallShield (then I'll move this thread to the InstallShield section of the forum)? If not please tell us what you are using and how you are installing the prerequisites.
