TIA
CA _AFTER_ moving files
Posted 07 March 2001 - 10:57
Posted 07 March 2001 - 22:42
Posted 08 March 2001 - 09:30
The best position is before the last position on execute tree.
I don't have understand the difference from Commit Execution and Defferet execution. Can you explain me, because the manual is not very claire in this point.
Posted 16 March 2001 - 01:18
For 'normal' custom actions, the installer will execute the actions as it is building the execution script. If you choose to 'defer' the custom action, what normally happens is that the action will be delayed until the position within the execution script. This is absolutely necessary if something in the install sequence must happen before the script runs. So setting a CA as 'deferred' delays execution until that point in the execution of the install sequence.
If you set your CA as msidbCustomActionTypeCommit , then it will execute ONLY if the IstallFinalize action is successful.
One thing to remember is that ONLY actions scheduled between InstallInitialize and InstallFinalize are scripted. That means that any action sequenced after InstallFinalize will not be seen by the installer until after the execution script is completed.
One difference between using the msidbCustomActionTypeCommit deferral and placing the CA at the end of the sequence is that on an Uninstall action, the CA's listed after InstallFinalize will be attempted. Those listed as msidbCustomActionTypeCommit will not ... but then you can differentiate your actions by using msidbCustomActionTypeRollback for the uninstall version of your CA, if you need one.
