1) The Setup.ini has a parameter called "CMDLine". Am I correct in assuming that whatever is put here is appended to the "Setup" command line (such as parameters for creating a log)?
2) Is there somewhere in the InstallShield IDE where I can specify what this is so that this parameter value is populated when the install is built?
Bob Rouse
Netuitive, Inc.
