When selecting Setup Type I give the user the option of selecting from three options, "Compact", "Custom", and "Full". I would like the highlighted option to default to "Full", but currently it defaults to "Compact" I'm assuming because it just starts at the top of the list. Can anyone help me out?
Can I select a default when...
Guest_Th
Posted 14 June 2001 - 19:24
Hi!
In the FirstUIBefore event in your script, make sure you have declared a STRING variable svSetupType.
Add a line before you call SdSetupTypeEx:
svSetupType = "Full";
Then call SdSetupType as:
nResult = SdSetupTypeEx (szTitle, szMsg, "", svSetupType, 0);
The dialog will appear with the "Full" option highlighted as the default, no matter where it appears in the list.
